If I bought a set of stagerred rims for my E36 would these fit?
Front 16x7.5 et13
Rear 16x8.5 et25
Any advice?
Ta
E36
Duke137
I don't think they will fit without arch mods mate. ET is too low as E36's use very high et's, 40+.
Await to be told different though
FMH
i had 17x8 et20 on my e36 which was lowered 80/60. 215 40's, only rubbed when i had 2 people in the back.
harry_p
The rears should be ok with the right tyres and and a slight roll.
Fronts will be tighter but not stupidly so, it depends how much work you want to do.
Also note you'll have to make the car stupidly low to pull off 16s. I had to wind my coilovers down as far as they'd go to get 17s tucked into the arches, it looked good but was a nightmare to actually use.
cheers,
harry
harry
