Couple of Alpina parts available prices needed!
325isporttech1
Post Mon Nov 15, 2010 5:10 pm
Ive got a e32 750i which may be getting fragged.These bits are no good to an e30 but i know you guys like to dabble in all kinds of bmw's like myself :D
The alpina bits ive got are staggered 17" alpina alloys all genuine, 8.5j at the front 10j at the rear with the correct tyre sizes, they have been refurbed but to a high standard but the caps are missing, after a rough price on these babys...
The other item is a genuine alpina momo steering wheel in excellent condition...
Would the best prices be obtained by offering these to the european market do you think?
Theo
Post Mon Nov 15, 2010 5:34 pm
Yes
Post Mon Nov 15, 2010 5:38 pm
The wheels are only suitable for an E32 which gives you a very small victim pool :(
325isporttech1
Post Mon Nov 15, 2010 5:44 pm
pacerpete wrote:The wheels are only suitable for an E32 which gives you a very small victim pool :(
So they dont fit the e34 or other 5 stud bm's then? thats a blow 8O
Post Mon Nov 15, 2010 5:45 pm
Cant they be bodged onto a 34 pete?
Would be interested in the cruise if its the separate loom type
325isporttech1
Post Mon Nov 15, 2010 5:51 pm
I have no idea dan if i frag it you are more than welcome to pop down to Telford. would of thought they would have fit the 6 or 8 series personaly but no little about this kind of thing.
Post Mon Nov 15, 2010 5:55 pm
Would they fit an E30 M3?
maggspower
Turbo Farmer Tractor Driver
Post Mon Nov 15, 2010 7:34 pm
pm sent :D
bigdoe
Post Mon Nov 15, 2010 8:28 pm
if it has sports front seats i would be very interested.
325isporttech1
Post Mon Nov 15, 2010 9:10 pm
bigdoe wrote:if it has sports front seats i would be very interested.
It has got them yes, they are electric lotus white leather :)
325isporttech1
Post Mon Nov 15, 2010 9:12 pm
Any ideas what the alpina steering wheels fetch guys? its looking more and more like a fragger it owes me just over £800 in total :(
bigdoe
Post Mon Nov 15, 2010 9:50 pm
sounds good, do you know if they will fit in an e34 without butchering them?, what sort of money would you want for them?.
325isporttech1
Post Mon Nov 15, 2010 10:01 pm
I think they are the same seats as in an e34 but i would check that one first, as for price im unsure yet as would have liked to have sold it all together and drivers seat has a worn bolster...will get back to you mate when know whats going on 8)
bigdoe
Post Mon Nov 15, 2010 10:13 pm
no problem, just let me know when your ready.
Andyboy
Alpina Colada
Post Mon Nov 15, 2010 10:23 pm
E32/34 front seats interchange, back ones don't.
leeparkes
Post Mon Nov 15, 2010 10:36 pm
What offset are the wheels?
325isporttech1
Post Mon Nov 15, 2010 10:48 pm
Lee as far as i know they are the standard offset for all 5/7/6 series except the e39 but will have to check that one,should they be stamped with the offset in the middle? Just found out the wheels and the steering wheel are the exact items found on the alpina B12.
And thanks andyboy for the info on the seats :wink:
Bigdoe will do :cool:
dickster
Post Tue Nov 16, 2010 9:46 am
I have the same size Alpinas put aside for my next big BM, as far as I'm aware your wheels will fit E34/E32 and 8-series, the only E34 they won't fit are the Tourings which have different rear arms which on 10" rear Alpina causes rubbing issues from what I've read when researching whar mine could fit.
1988 325i Sport
Post Tue Nov 16, 2010 11:12 am
10" rears foul the trailing arm on ALL E34s. You can grind the flange off the trailing arm and reweld it..... or fit 10mm spacers and have the tyres rub on the arch.....
Post Tue Nov 16, 2010 12:05 pm
What about E30 M3's?
325isporttech1
Post Tue Nov 16, 2010 4:55 pm
pacerpete wrote:10" rears foul the trailing arm on ALL E34s. You can grind the flange off the trailing arm and reweld it..... or fit 10mm spacers and have the tyres rub on the arch.....
That will be a problem for the next owner of them....still after some basic prices might be better of asking on the good old alpina board i guess :D
The B10 alloys fetch over £1000 all day long these are B12's and in a none original finish without centre caps so not expecting quite that much, but may get the caps and get them refurbed to original spec if its going to be worth my while which i suspect it will.
325isporttech1
Post Tue Nov 16, 2010 5:38 pm
These are the only ones i can find anywere....and they will fit the E30 M3 :D
http://cgi.ebay.com/ebaymotors/ALPINA-1 ... ccessories
Post Tue Nov 16, 2010 5:51 pm
325isporttech1 wrote:These are the only ones i can find anywere....and they will fit the E30 M3 :D
The seller is full of sh1t. B10 biturbos ALL came with 9.5" rears . I have owned several Biturbos and several E34 M5 tourings and have fitted 10s to both ONLY by cutting and rewelding the trailing arms.
A set of good E34 fitment 17s with good tyres and locks is £5-700 , the 10s are less desireable/ valuable. black and with no caps , even less so.
There are a couple of 7 series forums, your best bet is to post some ads, you should find a few victims there :)
325isporttech1
Post Tue Nov 16, 2010 6:03 pm
:o
Last edited by 325isporttech1 on Tue Nov 16, 2010 6:06 pm, edited 1 time in total.
325isporttech1
Post Tue Nov 16, 2010 6:05 pm
325isporttech1 wrote:They are actualy B12 alpinas been passed of as B10's then by the look of it
Victims is what im after pacerpete as im one myself for once :D
If its worth my while i will refurb them and track the caps down and offer them internationaly as money is thin on the ground in this country with everyone after a bargain(and rightly so)
Thankyou
