E46- common things to look for
bigwinn
Post Sat Oct 09, 2010 6:26 pm
Evening all
I'm thinking of getting an e46 for winter, I've had the coupes before (325 and 330 on 51 and 04 plates) as company motors, so if something went pop- back to the dealers and the company paid...
So now its mine, whats best to look out for on these:
2001 (Y) 325i convertible 97k miles
2003 (52) 325i 4 door SE 70k ish
both going into the mix... decision not made yet
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
johnt0709
Post Mon Oct 11, 2010 10:11 am
Control Arm Bushes
Rubber door seals perishing (fortune for the cabby)
Heater working correctly - google heater hedgehog
Rear parking faults
Water heater valves - jamming open - only get hot air
crank case breather hose - burst
airbag lights on - normally seatbelt pretensioner fault
vaccuum hoses leaking
Think thats about it
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
harry_p
Post Mon Oct 11, 2010 10:56 am
Rear subframe tearing itself off the floorpan
cheers,
harry
jimjim
Post Mon Oct 11, 2010 11:14 am
harry_p wrote:Rear subframe tearing itself off the floorpan
+1 Happened to my T reg 323i! Luckily the car had full history and BMW repaired it free!
Also airbag lights, Diff Bushes, Prop Donut, Prop Centre bearing and Oil gumming up/carbonating in the rocker cover where they have left it too long for a service.
bigwinn
Post Mon Oct 11, 2010 11:54 am
cheers! liking the Hedgehog thing!!!
darkchild
Post Mon Oct 11, 2010 12:19 pm
Had a 318ci for 18 months now. Lovely car but numerous faults:
Air-con that cost the best part of a grand (parts & labour) to fix (infamous hedgehog was one fault but there were several other things that needed replacing).
Broken driver's door handle. Had to lower the window before opening the door from inside. Nice!
Knackered door/window rubber trims (£250..........per side...........unfitted!).
Snapped auxillary drive belt due to an engine oil leak. No PAS, water pump etc - had to ditch the car and get it recovered before it cooked its engine.
2 rear parking sensors replaced.
Dodgy rear boot lock that seems to work when its warm but not when its cold.
Rocker cover gasket oil leak.
Crankshaft oil leak.
Luckily the vast majority of the above was repaired under warranty.
The rear subframe issues mainly affects the earlier cars (323i & 328i).
bigwinn
Post Mon Oct 11, 2010 6:36 pm
Darkchild- what kind of year you talking about- early or late?
darkchild
Post Mon Oct 11, 2010 6:39 pm
bigwinn wrote:Darkchild- what kind of year you talking about- early or late?
For what? :D
bigwinn
Post Mon Oct 11, 2010 6:41 pm
for your E46, what reg is it?
darkchild
Post Mon Oct 11, 2010 6:47 pm
2001 51 plate with the 16v valvetronic donk rather than the 8v M43. It had FBMWSH and only 59K on the clock when I got it too. In its defence its been pretty much faultless since the drivebelt problems last year but for a low mileage and obviously well cared for car its had more problems than my old E36 had in 80K/7 years. The N42 lump is very good when its working properly but isn't the easiest thing in the world to work on.
Lovely to drive but everything is just disposable. :(
bigwinn
Post Mon Oct 11, 2010 7:24 pm
cheers bud- agree with the disposable comment. shame as disposable does not equal cheap
