BMW X5 3.0D Swirl Flaps
BIGJO
Post Mon Sep 20, 2010 5:26 pm
Hi all,
I have been advised to change my swirl flaps because they seem to break away and fall into the engine 8O
Some of you will know what I am on about and some of you won't have a scooby doo.
Does anyone know of a place I can get this done?
I heard you can buy the replacement swirl flaps for £75 from somewhere.
There's a place which charges £200 drive in and out apparently? PMW?
They can go any time (swirl flaps) but usually after 100k...I have another 35k to go but wanting to do them ASAP because I don't want to risk it!
Any help is much appreciated.
Post Mon Sep 20, 2010 5:37 pm
PMW where advertising at £171 in Total BMW.
BIGJO
Post Mon Sep 20, 2010 5:51 pm
Wonderful thank you!!!
Andyboy
Alpina Colada
Post Tue Sep 21, 2010 2:42 pm
X5's don't have swirl flaps.
BIGJO
Post Thu Sep 23, 2010 11:00 am
Yeah I just heard from PMW...someone told me to check it out so I did. But atleast I can relax now 8O
bpowell555
Post Thu Sep 30, 2010 10:15 pm
Andyboy wrote:X5's don't have swirl flaps.
Bloody hell, a reason to get a X5. Why so? I would get at least three opinions on this before I rested easy. Its easy enough to remove the intake and have a gander yourself.
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
bpowell555
Post Thu Sep 30, 2010 10:25 pm
1990 325i touring
Post Thu Sep 30, 2010 10:26 pm
No need to remove the intake to check if its got flaps.
bpowell555
Post Thu Sep 30, 2010 10:48 pm
Why not?
1990 325i touring
Post Thu Sep 30, 2010 10:57 pm
Because if it doesnt have parts 9 and 11 in this link,
http://www.realoem.com/bmw/showparts.do ... g=11&fg=40
it doesnt have flaps. They are the vacuum control parts for the flap system and are located under the inlet but if you have a feel around the inlet you can see if they are there or not.
you can see the actuator under the manifold its on the lower inlet ports, fit the plugs you can get from ebay as its only for idle emissions. they open at about 1.5k rpm i think.
BIGJO
Post Sun Oct 03, 2010 9:18 pm
I spoke to PMW and they advised me that X5's don't have swirl flaps when they specialise in replacing these.
