e46 330i are they six speed?
I would image all the face lift ones are as my mates 320D (2004 facelift) is a 6sp and a rapid one at that
my 02 was a 5 speed
6 speed is available, seems to have come in later than the facelift. 5spd is perfectly adequate I've never found it too revvy/noisy on the motorway and 5th is all you need for most overtakes. 6spd really suits the M62B44 though....
Probably not a vast amount of help, but the diesels are 5 or 6 spd. Facelift cars '53' onwards are 6.
1988 325i SE h/c
Black sport leather, mtec suspension -60mm, LSD, tech1 steering wheel, chipped motronic 1.3 & numerous scabby bits R.I.P
2003 320d ES pov R.I.P Now in swirlflap heaven.
2001 330i SE MV1's
1987 M535i Alpine white
2001 330i SE MV1's
I can only manage 34mpg avg on a motorway run.Mostly avg 30.7mpg on the commute(100 miles)DanThe wrote:6th gear on my E30 is like icing on the cake, 37mpg over a 100mile journey at 80-90
But the E39 is about 1/3 ton heavier
- Contact:
Whats the final drive ratio on your 5 Dave?BadDave wrote:I can only manage 34mpg avg on a motorway run.Mostly avg 30.7mpg on the commute(100 miles)DanThe wrote:6th gear on my E30 is like icing on the cake, 37mpg over a 100mile journey at 80-90
2.93:1 IIRCDanThe wrote:Whats the final drive ratio on your 5 Dave?BadDave wrote:I can only manage 34mpg avg on a motorway run.Mostly avg 30.7mpg on the commute(100 miles)DanThe wrote:6th gear on my E30 is like icing on the cake, 37mpg over a 100mile journey at 80-90
