M44 1.9 from Compact-Z3?
eko
Old timer
Post Wed Jul 28, 2010 5:39 pm
What differences between the Two?
Both are obviusley the same engine but what will be nessarsary to drop the Compact engine into a Z3?
Compact is a 98 S reg and the Z3 is on a T plate.
eko
Old timer
Post Wed Jul 28, 2010 8:55 pm
Anyone on here done this?
Think im right in saying the Z3 is built on the E36 platform so im assuming the sump will be the sae,is the inlet likely to be aswell though?
Post Wed Jul 28, 2010 9:11 pm
The sump and mounting arms are the same as is the exhaust manifold Tony.
eko
Old timer
Post Wed Jul 28, 2010 10:10 pm
Cheers Barry,straightforward swap over then :thumb:
Post Wed Jul 28, 2010 10:17 pm
Even the front cross memeber/ subframe and wishbones are the same mate.
eko
Old timer
Post Wed Jul 28, 2010 10:30 pm
Only the rack ratio being different then?
Post Wed Jul 28, 2010 10:55 pm
Yes just the rack. Track rods and ends are the same.
