E60/E61 Front barke pads?
Andy325i
Post Fri Jun 18, 2010 8:45 pm
Anyone done them or know anything about doing them?
The car is a 2005 model
Many thanx
Andy
stonesie
Post Fri Jun 18, 2010 9:55 pm
I did a set on a 54 plate 525d, there's 2 different sizes of pad and if it has brought the warning light on the dash then it needs to be plugged in to re-set that.
The fluid reservoir is under the drivers side scuttle panel/pollen filter.
There is supposed to be a way of re-setting it through the dash but neither me or the cars owner could get that to work, lucky for me a friend does mobile diagnostics and is partial to a crate of stella.
It took me ages to type this, a couple of things kept distracting me winkeye
Andy325i
Post Fri Jun 18, 2010 10:04 pm
Thanx mate, the owner is confident he can reset it himself, if he does I'll let you know how :)
I can't imagine what is distracting you ;)
What tools did you use?
No silly tools to wind the calipers in etc?
Many thanx
Andy
glenn
Engine Transplant Services
Post Fri Jun 18, 2010 10:06 pm
:offtopic: .........................sorry andy,
did the shocks get there ok?
Andy325i
Post Fri Jun 18, 2010 10:10 pm
Hi mate, sorry thought I replyed :o: Yep A1 :) They will soon be in the parts section, along with the rest of the car :)
Many thanx again on the 1st class service :)
Andy
stonesie
Post Fri Jun 18, 2010 10:17 pm
I've got a proper calliper wind-back tool, a big pair of pipe grips or even a G clamp with an old pad would do the trick though, the nuts and bolts of it are just normal, you will need a 7mm allan key though.
Andy325i
Post Fri Jun 18, 2010 10:56 pm
Do the pistons need winding back or do they just slide back like E30's?
Many thanx again :)
Andy
stonesie
Post Sat Jun 19, 2010 8:38 pm
They just slide :wink:
Matt
irish320i
Post Sat Jun 19, 2010 11:20 pm
the pistons just slide but if your want the brake wear system to work you have to replace the wear sensor. no need to connect to diagnostics to reset warning it can be done through the dash
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Andy325i
Post Sat Jun 19, 2010 11:34 pm
Thanx guys :) What a palava to get to the brake fluid pot! lol
Also the outer pads from ECP had an extra bit on that wouldn't fit the caliper :s They soon god removed lol
Andy
