e36 compact question.....
spinner100
Post Sat Jun 05, 2010 4:45 pm
hi all.e36 with a majour whistle breather pipe is blocked some where, does anyone know where the crank case breather pipe is on theses and also what other breather pipes there is that could cause this... many thanks
Ant
Retired Team Member
Retired Team Member
Post Sat Jun 05, 2010 7:08 pm
M43 engine ??
Breather is routed from the back of the rocker box to the intake via the "zyclon valve", that is the random round disc looking thing on the underside of the intake @ the back.
does it make odd noises when switched off ? does it gurgle if you pull the dipstick out when running?
M44 similar setup, Zyclon jobbie even more inaccessible through :lol:
new pipe and valve is less than £40, pop some new parts on there dude.
Ant
Retired Team Member
Retired Team Member
Post Mon Jun 07, 2010 4:27 pm
Doh, missed that one Will :thumb:
