e36 Rear Bearings
johnna
- E30Zone Irregular
Is it meant to be this hard to get the hub off?
Be a man for once in your life and sh!t in that boot!- Wilfred.
StuBeeDoo
'Ello again Buddy!!
If the E36 is the same, or similar to, the E30 they are an absolute ba574rd. I did one on Easter Monday and it took me pretty much all day and I ended-up with blisters from all the braying with my 2kg lump hammer.
The touring's dead again!
johnna
- E30Zone Irregular
Nooo!StuBeeDoo wrote:'Ello again Buddy!!
Fancy setting up the dead touring club? I can join you if you stretch to e36's.
StuBeeDoo
Any touring accepted!johnna wrote:Fancy setting up the dead touring club? I can join you if you stretch to e36's.
My latest "woes thread" is here.....
I'd offer to come and assist, but I've got no transport.
johnna
- E30Zone Irregular
Swapping the rear bearing:
A shitplate putting the shit in shitplate- I wonder why the handbrake didn't work?:
That collar was tight tight tight:
My first extraction tool- guess its original application:
I welded in these plates to hopefully upset the collar (aye- right) and to set up a slide hammer (dream on).
I then utilised an old disc:
I bashed in the new outer collar using the old collar.
The front of the wind in tool (30mm socket):
The back of the wind in tool (36mm socket with an old inner collar fitted to it:
harry_p
if you have to do it again, run a bead of weld all the way round the inside of the outer shell, it really does help! on one bearing i did you could hear the shell 'crack' as it loosened it's grip, and drifted out easily.
looks like a crappy job though, i'd hoped the e36 arms would be a bit easier to get off and take to a bench.
cheers,
harry
harry
