m30b35 High idle problem
325isporttech1
Post Sat May 29, 2010 5:54 pm
Hi guys, its not an e30 but im having a little problem with the e34 535i touring. It has started to idle a bit over 1000rpm at times and when you are decelarating it seems to take longer than normal for the revs to drop like the throttle is stuck a little bit, and when it does drop its to about 1200rpm .
ive checked hoses for the usual splits and they look okay so im stuck for ideas?
