Just got this......
lance1a
South African/Scottish import
Post Mon May 10, 2010 6:43 pm
E34 525iX Manual.
Needs a bit of work, but no problem. In hideous green with mundane tan interior. Still....better in the snow than my other BM's or Mercs!
whipsey
Post Mon May 10, 2010 8:03 pm
looks same colour as mine but mines a slush box saloon with all the goodies fitted
Morat
Post Mon May 10, 2010 8:14 pm
Nice work! I was looking for one of these during the blizzards but we ended up with a Jeep Cherokee instead. Secretly I do like the Jeep now, but that iX looks just the ticket. What's the story with the drivetrain? I heard they have some clever stuff going on with the diff...
lance1a
Post Mon May 10, 2010 9:03 pm
I think it's very similar to the VW Syncro system. Problem is that the front suspension is COMPLETELY different to any other BMW due to the driveshafts on the front axle. This tends to make things a bit more expensive. But it's a decent old car that I will more than likely move on if I don't get a buyer for my SLC soon. :(
Post Mon May 10, 2010 9:26 pm
Nice. Love the wheels.
lance1a
Post Mon May 10, 2010 9:30 pm
Apparently the wheels are unique to the 4x4's, they are 16"'s with 225 rubber. I quite like them too.
TheHeap
Post Mon May 10, 2010 10:00 pm
Not what i would call a hideous colour
harry_p
Post Mon May 10, 2010 11:10 pm
i quite like it, looks very grown up and expensive.
cheers,
harry
gareth
Post Tue May 11, 2010 1:44 am
the LSD on these is computer controlled AFAIK, it's locked up by hydraulic pressure via a pipe from the PAS pump. rather nifty :D
lance1a
Post Tue May 11, 2010 5:58 am
gareth wrote:the LSD on these is computer controlled AFAIK, it's locked up by hydraulic pressure via a pipe from the PAS pump. rather nifty :D
As is the centre diff which varies the normal 36 front/64 rear split. Works in tandem with the self levelling. Which can be a bloddy disaster if the correct fluid is not used.
Fushion_Julz
Post Tue May 11, 2010 1:14 pm
The central "diff" (AKA Transfer box) is not controlled in any way, but works like a differential. It bolts onto the back of a standard gearbox.
The rear diff is a hydraulic item with pressure delivered to an accumulator (on the right hand front inner wing) from the back of the power steering pump and controlled by an ECU.
The rear suspension of the tourings is also SLS and also has two accumulators under the floor with pressure coming from the same pump...
The front suspension and subframe are entirely different to any other E34...The steering is rack and pinion (no box) and the engine sump is different with the offside driveshaft running through it and the front diff sitting alongside on the nearside. The rear propshaft is also unique as are the 16"wheels with an ET54 offset.
All the body panels adn interior trim, electrics and engine/gearbox are standard E34 M50.
I used to have an iX touring SE manual in Island Green with tan cloth comfort...Drives great, but is quite fuel heavy (21-23mpg) and isn't all that fast given the extra weight over a normal 525i.
The transfer box only has 0.5 litres of oil capacity so needs to be topped up/checked regularly if you don't want a £2K ish repair bill!
As Lance says...the correct fluid (CHF11s) in the sls/steering/diff system is a must
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Post Tue May 11, 2010 1:17 pm
Does that mean the iX has better steering feel with the rack and pinion?
Fushion_Julz
Post Tue May 11, 2010 2:09 pm
Blitz wrote:Does that mean the iX has better steering feel with the rack and pinion?
I would say yes...but my old E34 530 (M30) saloon had a good steering box so wasn't too shabby...But the iX was better in that respect.
TheHeap
Post Tue May 11, 2010 7:07 pm
Yeah 'til it's rather broke
gareth
Post Tue May 11, 2010 7:46 pm
...at which point the feed pipe can be connected to a hydraulic handbrake lever to provide an instant hooligan diff! :D
