Its possible by some indication know what engine is in the car despite the decals or VIN number by visual inspection. The 325is (2.5 lt. ) and 325e (2.7 lt) have some physical characteristic that can identifiable one each other???
325is or 325e 1988
bmw_pr
Hellow to all I am new in this forum and new with a 325is 1988.
jbh
- Hartge Crew
where is the redline on the rev counter?
325e
325i
See the difference in inlet manifold.
325i
bmw_pr
Thanks a lot Blitz, in normal condition is an excellent reference and I am sorry for insist; but suppose the engine block is from 325e and the head installed is from 325is with the 325i manifold.
How I can identified by any characteristic (any visual) if is 2.5 or 2.7
jbh
- Hartge Crew
my eta bottom end has 2.7 stamped on it but my mate's hasn't. you could try and measure the stroke.
bmw_pr
Blitz the manifold is from 325is for sure thank to your photo. But the engine block is my doubt. The comented combinationis is; a 325e block and use a 325i head, cam valves springs etc. intakue manifold including the computer control of 325i or is.
By this combination you can develops extraaaa horse power and more torque (2.7 block) with less friction in the crank shaft due to the less supporting bearing (3 less) instead of 7 supporting bearing in the 325i block crank shaft increasing friction but expand durability.
