anybody know what a e34 obc is worth?
is it worth selling it with all the wiring and storke or just on its own?
thanks
e34 obc whats it worth
robbo86
I will have the stalk off you. To be honest most of the wiring is there on an e34 so the loom will probably be worthless.
sheebie
How much is the obc n stalk worth?
What's ur offer on the stalk?
robbo86
I got an OBC already which I bought for 14 squid inc postage off egay. Will give you fiver for the stalk!
Fushion_Julz
All E34s other than 518, 520 and the diesels have the "high" instrument pack and that includes all the wiring and coding for the OBC. The dash also includes the repeater display, but the outside temp sensor and gong may not be fitted if only an analogue clock was standard equipment.
So all types of OBC, clock, check control modules are plug n play...
However, if you had an analogue clock, then the digital dispalys have a different holder which is also the radio panel surround....
The full OBC also has the stalk, as mentioned...
Full kits (panel, OBC and stalk) go for around £20-35
If you have the "low" console, then you can still fit the OBC, but you won't get the repeater display and you have to fit a coding plug to the back of the main instrument cluster.
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
