bmw m635csi (m88) injectors
seanboy
Post Wed Feb 24, 2010 9:44 pm
Guys does anyone know if these are m88 specific or will injectors out of a m30 have the same lb pressure/fitment.
Realoem reckons it could work, listing two part numbers for the m30, one for m88. one part number from the m30 is the same as m88 listed!
Heard that a few items were inter changable between M30/M88?
Cheers Sean.
BadDave
Post Wed Feb 24, 2010 10:20 pm
If you can get the bosch part number for the M88 and the M30 you can check here to see how they compare
http://users.erols.com/srweiss/tableifc.htm
I'd hazard a guess and say the M88 ones have a higher flow rate than standard M30 ones
