e46 330ci tech help please
My brothers e46 is using oil randomly. It is not leaking or obviously burning any. He has read on other forums that something called a 'PCV' could be the cause??
Is this like a crankcase breather/valve or something?
Any ideas of where to start?
Cheers!
Cheers!
Ok IRC valve then
Number1 on the link below:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
Could this be the culprit?
- fowler
- Boost Junkie
- Contact:
thats not to bad dave as mine has done half a litre in 1500-2000 miles but as people have stated the 330 have been know to use oil plus it prob gets driven hard from cold
EX A-Tech Workshop bitch !!!
gone but not forgotten
That is normal for an M54B30 using 5w30.oakey wrote:We're talking a litre with 1000k miles.
I spoke to Ant today about it Ben^ and I'm gonna get my bro to take it up there as it needs fluids and filters etc done anyhoo
Some specialists recomend using 10w40.
- fowler
- Boost Junkie
- Contact:
i use 10w-40 in the 323i E46 just keep it as they are good cars
i am sure the oil is just too thin and being absorbed by the engine
10W40 is fine.
stuartgallafant
personally i wouldnt use 10w 40. takes too long to thin up, cools down quicker, basically completely different from 0w 30 which is what its meant to use
BMW reccommend that 1 litre to every 1000 miles is not a problem. We get so many people come in at work complaining about oil usage, but there's not a lot you can do. the 330's are the worst of the bunch, even worse than the diesels i find, but i suppose its the way people drive a 330!!
Oakey, those breathers can get clogged up badly, but im not sure i recollect changing one for oil usage, more likely poor idle and lack of power.
If you wanna put your mind at rest, they're only cheap!!
