Video: http://video.google.com/videoplay?docid ... 8066992482
BMW E46 Subframe issues
78dude
This looks very dramatic if you ask me, I found this information on a Norwegian car forum and here is the video of it...
darkchild
Ah, E46 323i and 328i wrongness. The days of the E32/E34 are long gone when BMW would build a car to the highest standard and simply add a profit margin on top.
JazzMan
Yeah luckily I have one where they had already started putting the ticker metal in the rear, I do give it a good inspection when ever it comes to service time to be sure though!
nickso
- Location: Go do that voodoo that you do so welllllllll!!
what year would that be out of interest?JazzMan wrote:Yeah luckily I have one where they had already started putting the ticker metal in the rear, I do give it a good inspection when ever it comes to service time to be sure though!
'88 e30 328i M52 track bint.
Mox3d
Circa 98 to 01 or 02
JazzMan
IIRC it was around the time the M54 was introduced.nickso wrote:what year would that be out of interest?JazzMan wrote:Yeah luckily I have one where they had already started putting the ticker metal in the rear, I do give it a good inspection when ever it comes to service time to be sure though!
nickso
lol sorry to be a pain but what year is that, i know fuck all after the e36 really.JazzMan wrote:IIRC it was around the time the M54 was introduced.nickso wrote:what year would that be out of interest?JazzMan wrote:Yeah luckily I have one where they had already started putting the ticker metal in the rear, I do give it a good inspection when ever it comes to service time to be sure though!
01/02 as moxed says?
JazzMan
I did a bit of looking around looks like it was sorted as of Feb 2000
Mox3d
Without checking I believe you're bang on. I tried to allow for later registered but early built cars. Hope that makes sense.JazzMan wrote:I did a bit of looking around looks like it was sorted as of Feb 2000
nickso
so feb 01 to feb02 is the car you want to avoid athe back end falling off and also to avoid the later tax issues. will have to remember that if i ever get an e46.
JazzMan
I've got a 02 plate, tax is £210 this year on a 320Cinickso wrote:so feb 01 to feb02 is the car you want to avoid athe back end falling off and also to avoid the later tax issues. will have to remember that if i ever get an e46.
nickso
oops, i wasnt thinking when i wrote that. the car needs to be pre march 01 to beat the taxman. so what i meant was feb00 to feb01.JazzMan wrote:I've got a 02 plate, tax is £210 this year on a 320Cinickso wrote:so feb 01 to feb02 is the car you want to avoid athe back end falling off and also to avoid the later tax issues. will have to remember that if i ever get an e46.
A friend of mine had a 99 V reg 328Ci which had this problem as cracked the subframe mount on the nearside. It cost him the best part of a grand to be welded up!
This problem isn't exclusive to the 6 cylinder models either!
This is a W reg 2000 model 4dr 318i which came into my work for a noise from the rear,
this is what i found!
bss325i wrote:A friend of mine had a 99 V reg 328Ci which had this problem as cracked the subframe mount on the nearside. It cost him the best part of a grand to be welded up!
this is what i found!![]()
No trev, they were told to scrap it!
JazzMan
SamiS
- Formerly illmonkey
BMW are 100% aware of this issue and will fix it if you put a bit of pressure on it. My '99 323Ci had this and I took it in, they called saying they've found out and will get it sorted within 4 weeks. I didn't even need to push them.
Take a look here: http://www.e46zone.com/forum/index.php?showtopic=103
And you can see here there are hundreds with the issue, this helps when you argue with BMW!
http://forum.e46fanatics.com/showthread ... 02&page=60
Pilsbury
Interestingly, this is rather similar to the issue that affects the Z3...
E12 M535s were similarly afflicted !
Jon_Bmw
- Dangerous when thinking
I have always heard of people talking about this issue, but christ it is worse than I thought! Barry, are you sure thats not a c5 or something!
Mox3d
The vary same. Earlier z3's, same era.Pilsbury wrote:Interestingly, this is rather similar to the issue that affects the Z3...
Pilsbury
Do E36 Compacts suffer from it too, as they are mechanically very similar to the Z3?
harry_p
i thought the z3 issue was more to do with the diff 'ear' mount tearing away from the boot floor, rather than the subrfame mounts themselves.
there have been some high power e30s that have suffered the same, and no doubt given enough power compacts would suffer too. most only have small engines so it's not likely to show up as often.
cheers,
harry
harry
Pilsbury
The Z3 suffers from subframe and diff problems. I heard of it happening on everything from 1.8's up.
I know there were 6 pot Compacts in LHD.
