Anyone removed a steering lock assembly on a e34? dunno if the engine size makes any difference, but I have a 535. Just not too sure how to get out the shear bolt on it? Do I have to take the instrument cluster out?
thanks.
steering lock removal
monkey
if its just the lock you need to remove . i think you can remove it in the same way as an e30 by turning the key to position 1 and pushing a small drill bit in the hole beside the lock to release it then pull the lock out . to remove the shear bolts use a punch or chisel and hit the head of the bolt around until its loose .
whipsey
or use a hacksaw blade and cut a groove into the bolt when its fairly deep get a screwdriver in there
theweapon
yeah, its the whole bit (which i will post pic of in a min) the thing is, the shear bolt is right against the dash. seein if anyone had done one before, n what i gotto remove n that
whipsey
sheer bolt should be underneath the dash unless the barrels in backwards what year e34 was it in?>
theweapon
its a 91. You can see the (black) shear bolt on the top of the pic, where I put it in loosely,
whipsey
that looks upside down for some reason just took one off a j reg 520i and it was underneath
theweapon
thats 100% the right way up as shown. same as it is in the car
whipsey
have you got an adjustable steering column?
theweapon
yeah. manual adjustment (not electric)
