A friend of mine bought an 88 520 with the intention of converting it into a track car. It has an M20 b20 at the moment and he is considering replacing it with an b25. I assume the engine from a 325 could be used as it might be easier to find one rather than a 525 M20.
Would the engine be the same as the facelift e30?
He is not experienced changing engines so just wants a simple plug and play swap
e34 M20 engine
Let me get this straight E34 520 as a track car?! you serious? they are a mobile road block!
Theo
A facelift 325i engine would slot straight in, you'd just need to use the engine mounting arms from the 520i engine.
However, it would still be a bit pedestrian given the e34's not inconsiderable mass. He should at the least fit a m30 3.5, or even better a M60 4.0 if he wants something which would be more entertaining.
wrcarter
Thanks. I would agree its not going to be quick but its what he wants to do. Think its more the fun of the project than the power.
scootlife
Wouldnt an E30 be far better even a more door ???????Simon13 wrote:Let me get this straight E34 520 as a track car?! you serious? they are a mobile road block!
yup, e34's drift better longer wheel base. But you'd want a load more power
