Where does an E34 rot (common places)
leeparkes
Post Fri Jan 02, 2009 6:26 pm
as above.
going to see one over the weekend for my engine conversion,
im hoping its as rotton as a pear but where are the common (mot failing) places for them to go?
thanks (in advance)
Post Fri Jan 02, 2009 9:07 pm
Bottom of wings, lower rear sills and rear arches
M50? :)
**BANNED**
Post Fri Jan 02, 2009 10:01 pm
As above but add fuel tank and brake lines.The one I bought as a donor also had an entertaining habit of leaping to the left when changing up when,erm,'pressing on?' :o:
Youth is wasted on the young.
wullie325i
CAUTION - unreliable trader!
Post Fri Jan 02, 2009 10:06 pm
daimlerman wrote:As above but add fuel tank and brake lines.The one I bought as a donor also had an entertaining habit of leaping to the left when changing up when,erm,'pressing on?' :o:
i have one at the moment that does this aswell :roll:
Post Fri Jan 02, 2009 10:19 pm
Rear axle mount bushes most likely, ive only ever seen plastic fuel tanks on E34's Malcolm, was yours a steel? Been after one for a while
leeparkes
Post Sat Jan 03, 2009 12:33 pm
DanThe wrote:Bottom of wings, lower rear sills and rear arches
M50? :)
going to look at two,
M50 and a low miles M30,
both have no tax/mot
**BANNED**
Post Sat Jan 03, 2009 3:33 pm
DanThe wrote:Rear axle mount bushes most likely, ive only ever seen plastic fuel tanks on E34's Malcolm, was yours a steel? Been after one for a while
No,plastic tank,but it leaked when over half full,or half empty if you are a pessimist...did not bother with it as I was breaking the thing anyway...Andyboy ended up sticking a centre punch into the lower L/H corner so that I could rescue the last three gallons!! I reckoned the handling trick was axle carrier bushes,the thing really should not have passed it's last MoT,brake lines were in a shocking state.Engine's sweet,though :D
Post Sat Jan 03, 2009 4:26 pm
At least is does not rot like an E30.
dave525
Post Sun Jan 04, 2009 4:53 pm
front arches and wing bottoms.jacking points on sills and also rear of sills.inner sill at front as sunroof drain goes into sill.mine is holed but outer sill still ok.fuel pipes under car.most rust seems to be localised as some parts are galvanised.
jamie323i
Post Tue Jan 06, 2009 7:28 pm
Just like to add the area around the petrol flap can also rust badly,seen a few with the dreaded tin worm around there :eek:
Zerotonine
Post Tue Jan 06, 2009 10:44 pm
fuel lines rot like a bitch, and the old beast I owned used to love to dump petrol onto the exhaust, used to pull to the left, steering was shot, O/S wiper arm being chewed off by the bonnet, but otherwise fairly solid, I don't think they actually rot too badly really compared to other cars, just if it has been neglected everyting else on the car turns to shite
Finally promoted to Regular! Only took 7 years...
