pipes on bottom of air box 95 m50b20? can i block them off?
wullie325i
CAUTION - unreliable trader!
Post Sun Nov 23, 2008 9:55 pm
hi
my partner bought a 95 520i and its got no air filter in it but i have a induction kit i can stick on it till i get a new panel filter but theres 2 pipes on the bottom of the air box that go to a valve on it which go to the tb and icv i think so my question is what can i do with these pipes while im using the cone filter?
i would appreciate some help asap as its getting rather cold out lol! :mad:
wullie325i
Post Sun Nov 23, 2008 10:02 pm
can anyone help me out i want to get this done and in for the night? :(
wullie325i
Post Sun Nov 23, 2008 10:07 pm
haisty bumpo!
wullie325i
Post Sun Nov 23, 2008 10:14 pm
anyone?
wullie325i
Post Sun Nov 23, 2008 10:22 pm
would it be ok th leave the icv one open and seal off the one to the tb?
wullie325i
Post Sun Nov 23, 2008 10:23 pm
would really appreciate a hand on this so i can get in people please :cry:
wullie325i
Post Sun Nov 23, 2008 10:27 pm
bumpo
wullie325i
Post Sun Nov 23, 2008 10:30 pm
come on someone must know what i can do with these pipes?
wullie325i
Post Sun Nov 23, 2008 11:53 pm
had another look and i think one pipe comes from the top of the block and the other from the throttle body.
for now i have joines them together but can someone tell me if that will be ok?
Post Mon Nov 24, 2008 12:05 am
If these pipes are what I think they are, they are coolant pipes for the throttle body heater, and the 'valve' in the air box is a thermostat.
The simplest thing to do would have been to just unbolt the 'stat and cable tie it to something nearby.
It sounds like you've taken the 'stat out of the circuit, leaving the TB heater permanently on. This will cause a minute decrease in power, but cause no other problems.
**BANNED**
Post Mon Nov 24, 2008 11:40 am
Brianmoooore wrote:If these pipes are what I think they are, they are coolant pipes for the throttle body heater, and the 'valve' in the air box is a thermostat.
Thanks,Brian,that has answered a query I have with my M50 swap!! Hope it has helped the OP as well.
wullie325i
Post Mon Nov 24, 2008 6:26 pm
thanks brian :D
