2002 Engines
ShakeyC
Post Sat Nov 08, 2008 5:47 pm
What engines would be good in a 2002 thats fairly easy to get hold off?
320ise
Post Sat Nov 08, 2008 5:50 pm
e30 m3 engine would be nice! but an m20 should go in easy enough, a nice change would be an 1.8 i.s engine that would be nippy and balanced.
GrindCulture
Post Sat Nov 08, 2008 5:57 pm
I certainly wouldn't want to put anything bigger than an M20 in something as small as a 2002. M42 or S14, depending on budget :D
How about a non-bmw 4pot?
Not in E30s any more :(
Rosc0PColtrane
Post Sat Nov 08, 2008 6:31 pm
s14 is a popular choice, I have a picture of a 'M2' somewhere. Possibly the best choice in terms of weight and power.
ShakeyC
Post Sat Nov 08, 2008 6:37 pm
Where's the place to look for S14 please?
Non-BMW 4 Potters welcomed too
Theo
Post Sat Nov 08, 2008 6:46 pm
sr20det :)
fuzzy
He who sleeps with "Gingers"
Post Sat Nov 08, 2008 6:52 pm
cosworth yb. obviously.
zaust
Zone day release
They never reached the full potencial of the engine the ti came with so why change it. (m10 + turbo) They only ever used blocks that had 10k + on them too, to make sure they were proven.
M30 Tech 1 Touring on gas.
BigBavarian
Post Sat Nov 08, 2008 7:21 pm
We're planning on a 2.7 into a 2002, have the bits for the engine just need to sort the shell out, uprate the brakes get a lsd etc...
Richard
320ise
Post Sun Nov 09, 2008 7:42 am
e36 i.s motor tweeked to round 150-160bhp would be a revvy little monster with the rite gearing.
lance1a
South African/Scottish import
Post Sun Nov 09, 2008 8:12 am
M10 motor that's already in there. I have a 2002 ti block overbored to 2010cc and a 121 head with 292 cam. run on twin webers or bike carbs it should give 160bhp. Strap on the FI from an early 318/518i and blow it and get a lot more, though you wouldn't be able to use the 292 cam with a blower. M10 also used as Brabham BT52 formula 1 motor, big following and loads of cheapish parts from the states. The M10 served as the basis for the first M3 anyway. Very strong motor and capable of developing a lot more power than most other motors of similar capacity.
BMW E28 528i X2
Merc W126 300E twin turbo
Merc cosworth 190e 2.3-16
BMW E28 525E
BMW E28 M535i
Saab 900 Classic Turbo
BMW E24 Highline Cosmos
BMW E24 Highline silver
BMW E24 Macau Msport
BMW 1972 2002
BMW E36 Alpina B3 3.2 Switchtronic
Renault
e30bmlover
Ac Schnitzer prophet
Post Sun Nov 09, 2008 12:24 pm
320ise wrote:e36 i.s motor tweeked to round 150-160bhp would be a revvy little monster with the rite gearing.
pah! why waste time putting an anchor like that in to it?!?!?
s14 ftw.
e30bmlover
Post Sun Nov 09, 2008 12:25 pm
fuzzy wrote:cosworth yb. obviously.
good choice fuzzy... but i cringe at anything ford going into a 2002! hell i wouldnt even put anything schnitzer on it, its just not right!
pnd
Post Sun Nov 09, 2008 12:27 pm
An early m20 2.5 in an 02 goes very well S14's are too expensive
320ise
Post Sun Nov 09, 2008 2:04 pm
only said i.s as m3 engnes are silly money! and it would be a responsive car if set up correctly, an m20 would be fast i bet but in corners mite suffer as i would imagine in the 2002`s engine bay you would have to re-mount the headlights on the rocker cover! (allthough i have seen one done and they do just fit) the i.s would be more like the existing weight of the m10 or even ligher? not sure on that one!
(ps how much does an s14 weigh over an m42/44?)
ShakeyC
Post Sun Nov 09, 2008 6:44 pm
Would love an S14 or 2.0l M10 to be eligable for the rules and regulations in many Historic and Classic races and series. Unfortunately not seen any for sale for long time or sensible money hence this topic, if none pop up im going all out for maximum wrongness :eek:
lance1a
Post Sun Nov 09, 2008 6:58 pm
You can have mine for £500.00. Needs assembling though and all part are new and parts not fitted are waiting at BMW for me to pick them up and pay for them.
121 head 44mm/38mm valves with D'Bilas 292 10mm lift cam (brand new) newly rebuilt by Rob Walker Performance.
2010cc 02 block with brand new (not fitted) Payen rings. Recently honed and requires only minor bits to finish....EG: big end set and to swap over the sump etc from std M10. :D
BMW E28 528i X2
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
Morat
Post Wed Nov 12, 2008 2:04 am
Integrale engine - buy an early (16V) Fiat Coupe from a scrappie!
190bhp, 220lb/ft. I've no idea what you'd do for a prop :(
Fushion_Julz
Post Wed Nov 12, 2008 8:12 am
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
e21Jason
Post Wed Nov 12, 2008 12:57 pm
Hi
There was a 02 being rebuilt in my mates gargae who also does a lot of classic jap so we took a few mesurements and the 180sx turbo motor and box would fit, the exhuast & turbo is on the passangers side so it's a simpler install.
Fritz are doing a m42 conversion and I have a s14 motor stashed for my tii.
But if you want power just turbo the motor that's in there
Jason
Jon_Bmw
Dangerous when thinking
Post Wed Nov 12, 2008 1:17 pm
So I presume turbo options are out the window then as they won't meet regulations unless its a 1.4 turbo or something like that.
Vauxhall XE engine on throttle bodies ftw. I would suggest an Mi16, but the ability to make it RWD is rather challenging. :o
ShakeyC
Post Sat Nov 15, 2008 6:43 pm
To answer the questions it has no engine at all so im hunting for one.
The regs for the class state the engine has to be from the same family or if its an ex-racer (which it isnt) can use that family of engine too as some did run pinto, cosworth, lotus engines back in the 70's.
I have some other options but will not be allowed to race in any historic or classis series so defeats the object really :cry:
ShakeyC
Post Sun Nov 16, 2008 9:01 am
We was originally thinking more zetec turbo than yb just for maximum righteousness ! :cool:
e21Jason
Post Sun Nov 16, 2008 11:42 pm
Turbo m10 as there was a turbo 2002 in the day is the cheapest BHP as a 220HP NA m10 is about 5k
Jason
