i have a x reg 318ci coupe, car had n/s/f suspension damage when replacing the hub i replaced it with a new abs sensor, the abs light came on as a result but when i started driving went off, i have had it on the bmw comptuer to reset and erase the fault code but the problem im having is that when i brake and slow down to 5-10mph before coming to a complete halt the abs kicks in car was perfectly fine before and there are no fault codes showing,,,,,, any ideas????????
thanks,
billy
