Number plates
dano0
Not sure if this is the right place to post but where is the best place to get german style number plates . Also not sure if i should put a private plate on or not I have one witch reads A32WON or keep the original E197VFD Whats every ones point of view .
march109
www.dubmeister.co.uk supplier of road legal UK pressed plates, or take your chances and get german plates from them too.
Be aware if you are caught with German plates more than once the DVLA can remove your private plate index from you, if that is the registration you are using, so if you go this route I would use the standard reg.
dano0
i thought that they were just ment for show,s
march109
yes but get caught with it more than once and not only the fines will rack up you'll loose your reg too.
dano0
Just been playing around and it looks better with a longer reg i think cheers for the web link MARCH109 . Also the UK legal pressed plates look good as a compromise don't think there be legal for long tho what with the legislation changing on UK plates every 5 minutes.
