Another E36 issue
Zerotonine
When I start my 316i up when cold and switch it off after a short run there is a smell of petrol, which disappears after a couple of mins. The smell seems to be coming from the top of the engine, any ideas? I checked the fuel feed/return and the pipes look fine.
Jeepster
It will be the carbon cannister i bet, its on the nearside inner wing.
The fuel lines under the inlet manifold perish and weep
Demlotcrew
ding!DanThe wrote:The fuel lines under the inlet manifold perish and weep
Jeepster
Yeah, but then he would have the smell all the time, the carbon canister is to vent the fuel tank, so it should only really smell if its cold surely.
- **BANNED**
My late(K plate)touring is fitted with this gadget,and smells of petrol!! What is the cure?Jeepster wrote:Yeah, but then he would have the smell all the time, the carbon canister is to vent the fuel tank, so it should only really smell if its cold surely.
Jeepster
Replace the carbon canister really, I imagine its stopped filtering the smell. I would check that all of the pipes are ok first though.
Zerotonine
How much would it be to replace the canister? I cannot see any physical leaks on pipes, it is only 5 mins from cold then it stops smelling completely.
Jeepster
I think they are about £30, not sure if the likes of GSF stock them.
Zerotonine
Gonna pop down GSF in vain hope that they might have one, been slightly distracted by my new project car to sort this issue out.
jibowski
i've had this on 3 m40's that i've had only for a moment when the cars warming up say 3-5 mins after starting never when cold or hot, just ignored it myself
No E30s at the mo!!
2002 Seat Arosa TD I
1996 Saab 900 turb0
1996 Saab 900 turb0
