e36 328i nikasil
dips346
London Meets Main Man
Post Wed Jun 25, 2008 11:31 am
i am about to sell my e36 328i tourung on a p reg ,how do i find out if my engine is a nikasil one or not ,i remember something about a marking on the block ,any help ?
BMJG
Post Wed Jun 25, 2008 12:35 pm
When looking at the engine from the passinger side down by the starter and where enginr touches gearbox you shoud see a shiny ish plate 50p size then it's ausil and ok. there is a quick check guide on e36coupe in the FAQ section as well
dips346
Post Wed Jun 25, 2008 12:43 pm
BMJG wrote:When looking at the engine from the passinger side down by the starter and where enginr touches gearbox you shoud see a shiny ish plate 50p size then it's ausil and ok. there is a quick check guide on e36coupe in the FAQ section as well
cool ,should have checked they :o:
M3Macao
Post Wed Jun 25, 2008 3:27 pm
Also ask BMW to check the VIN to see if it had its recall to have a new block fitted. Like BMJG said an Alusil block will have a pear shaped blanking plate down near the starter on the n/s.
I went through the same processes when i was looking to buy a 328i sport. The one i have is an April 98 car which had the alusil block fitted from the factory.
Hope this helps.
Post Wed Jun 25, 2008 6:36 pm
No M52 engine had alusil coated bores, that is just chinese whispers created in E36 forums. The replacement blocks have steel liners which can create a whole new problem
Post Fri Jun 27, 2008 7:02 pm
like sinking alloy and headgasket failure?!
Post Fri Jun 27, 2008 7:51 pm
I think the whole nikasil issue is over hyped. Theres many BMW with nikasil that run fine with high miles. These days most petrol has a low sulfur.
Post Fri Jun 27, 2008 11:02 pm
Its not over hyped at all, ive yet to strip an M52 with no bore wear, even engines that have run ok have still had bore wear
