Mini Service
SK360
Post Tue Jun 03, 2008 10:15 pm
Hi, Just wanted to get some info from any experienced Mini owners or anyone that knows how to give them a basic service, as Im going to attempt servicing my girlfriends one, (should be good) :?
Any hints or tips, what parts to go for would be much appreciated :)
I was going to do:
1, Oil
2. Oil Filter
3, Spark Plugs
4, Reset Service Light - This im not 100% sure about but read how to do it on the internet.
Anything else?
Thanks,
S.K.
stonesie
Post Tue Jun 03, 2008 11:07 pm
To get at the oil filter you might need the drivers wheel off, its a paper element type, also have some antifreeze handy as the expansion tank is above the exhaust manifold some of them do evaporate the coolant away.
As services go theyre not a bad job, good luck :wink:
dickster
Post Tue Jun 03, 2008 11:11 pm
I take it from the service light question you're talking about the new/BMW mini?
I wouldn't do spark plugs on a small service unless it needs it-also I would check to see if they are platinum plugs if so they don't need changing as often as normal type spark plugs-but when they do they are very expensive, but its your choice and you won't do any harm by fitting a set if they're reasonably priced.
If you're doing a small service then just oil, oil filter, check all lights and fluid levels and tyre pressures etc, check air filter (I think from memory there are two types of air filter) as it won't do you any harm to check...unless you somehow break something, I'd check the pollen filter too as they often get overlooked. I'd prob just have a quick glance at the state of the brakes-is there enough meat on the pads left?-you can be caught out as you might not be able to see the inner pads, and check the discs-are they excessively worn? any lips around the inner and outer areas where the pad makes contact on the disc and is there any really bad/deep scores worn into the disc?
This is by no means a comprehensive check list as you can tell and its up to you how far you want to go, what did it have done last time and how long ago was it-thats what you should ask yourself.
I'm the service manager in a garage by the way! :wave:
1988 325i Sport
SamiS
Formerly illmonkey
Post Wed Jun 04, 2008 8:08 am
Is the car not under TLC (free servicing)? How old is it?
TLC (if bought) it runs for 5 years from new, then you can top it up again.
zimmerbimmer1
BMW Parts Meister
Post Fri Jun 06, 2008 10:37 am
If the car is less than 5 years old and 50k the car wouls be covered under the TLC if ordered when the car was new.
If it is I strongly suggest paying £300 and have it extended to 8 years 80k.
A basic service on those would be oil filter and microfilter
:D.
