BMW 2002's Any good?
wildeian
Seen a cheap 'project' and was wondering if they are any good?
Will a M20B25 fit??
Cheers.
Will a M20B25 fit??
Cheers.
They are sad horrible leaky smelly old turds, like their owners !
oldroydsr4
If a 2002 is cheap , it will be rotten. Fact!!
wildeian
Bugger!!
Need to keep looking for a project then!
bilun777
Who rattled your cage then.I've owned 4 over the years ,they are a delight to drive . Light weight ,fantastic visibility and easy to work on. they do rust like f**k.My golf yellow tii will hopefully be on the road again next year.[Like it's sad horrible leaky smelly old turd owner.]pacerpete wrote:They are sad horrible leaky smelly old turds, like their owners !
If it aint broke don't fix it!
bilun777
Quite true. The engine of choice is the s14[4 cyl m3] same block as the old m10 in the 2002.Lots on american sites.Make your own M2.oldroydsr4 wrote:If a 2002 is cheap , it will be rotten. Fact!!
Rosc0PColtrane
wildeian
That's the picture that got me thinking!!
jaistanley
Thats a LONG way off an std 2002!
The M20's wont fit. The engine bays are tiny. You can get the S14 and the M42 in there though.
TopSod
That's waaayRosc0PColtrane wrote:
suzie650
The M20 does fit. I don't know how much modification is needed, but I've seen it done by an ex-employee of Jeff Ireland. Had a 3l stroker in as well
Ziggy
Wouldn't be my choice of engine though!
Rosc0PColtrane
At least it'll sound proper!
No more typewriter din!
buzz6353
bulkhead and transmission tunnel need a bit of re modelling to say the least
Some guys cut the front panel as well but it is not needed if you do the tunnel right
