EndaW wrote:Dyno mode.
Hold the car at 4000rpm on the dyno, press and hold the traction button for 10 seconds, let car drop to idle by pressing the clutch.
Then dyno the car as normal reaching max rpm.
The original car was tested using 102 octane and at 17.8 degrees (din 90020)
You will never get m3 power using 98 octane and no where near using 95.
You lot worry about genuine power figures, thank your lucky stars you dont own a ferrari, lambo or TVR !!!!
Is this the same for the M5??
If it was Thorney Motorsport, I would say they know what they are doing. The figures being banded about for this car do seem odd....but also, and I am not saying its the case with this car, Porsche's "learn" how you drive the car and set a map which is the best for how the car is being driven...in this case it could have been economy. If the car was well looked after, then maybe it wasn't driven past 4000RPM untill your friend bought it. If it was driven like a loon from day one, the story maybe different.
I have heard that 40BHP or thereabouts can be had by remapping the E46 M3, but nothing is gained below 4000 RPM apparently?? I am yet to do one myself, so can't speak from experiance - YET!
www.sabre-tuning.co.uk
