Here's todays bodge using all oem parts
Brake servo pipe with a bolt in the end works a treat on blocking the dipstick tee
For the breather pipe from the rocker cover i thought id use part of the oil separator piping as it clips in and a pipe can be easily took from it (not cliped in yet)
^^^will this do with just a pipe running to the inlet boot or do i need more bits? ie this link vvv
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
Now im seriously considering rigging the traction control up on this swap as it wont just be me using the car, the wife will be using it too and the last thing i want is to hear is she's smashed it up as ill be less than impressed, she can handle a car but i sometimes have my doubts.
Anyway i have all the traction control gubbins from the donor car but the M52 rubber boot only has one hole for the ICV, is there a rubber boot that i can use that has two holes? ie for the breather
