E46 325ti
Andyboy
Alpina Colada
Post Thu Jan 17, 2013 2:03 pm
capri_rob wrote:Mine had done 76k and was starting to grumble
E46 rubbish. 80'000 mile pump on the Laguna was like new but fitted a new one whilst doing the belt.
Post Thu Jan 17, 2013 6:03 pm
The water pump on your gallic sh1tbox may well be fine Andy - its the rest of the car you need to worry about - if it has the 6 speed box and its done 80k you'd better get ready to change it - my Mrs Laguna made it to about 75k before the box shat itself :mad:
Andyboy
Alpina Colada
Post Thu Jan 17, 2013 7:00 pm
Blimey. 'Car with potential problems' shocker*. Whatever next?
Tell you what - I bet your quality E46 has had more new bits than this unreliable French rubbish......
*both rear ones still dry btw. :D
Post Thu Jan 17, 2013 9:53 pm
Andyboy wrote:Blimey. 'Car with potential problems' shocker*. Whatever next?
Nope - not yet anyway - previous owner just had it serviced - looks like actually replacing stuff will be down to me :banghead:
Post Thu Jan 17, 2013 10:18 pm
Sacre bleu!! Quelle horreur! :eek:
Andyboy
Alpina Colada
Post Fri Jan 18, 2013 5:57 pm
More like this Dan:
Post Fri Jan 18, 2013 6:31 pm
capri_rob wrote:The water pump on your gallic sh1tbox may well be fine Andy - its the rest of the car you need to worry about - if it has the 6 speed box and its done 80k you'd better get ready to change it - my Mrs Laguna made it to about 75k before the box shat itself :mad:
Ah, the PK6 gearbox made of cheese!
At least its not an auto, they only did about 30-40k before dying!
Andyboy
Alpina Colada
Post Fri Jan 18, 2013 8:45 pm
Depends which one. The ZF was not bad, the DPO a disaster. That piece of shit was fitted to lots of French turds. Changed the pollen filter on the red turd today, admiring the lack of rusty arches ;-)
Post Fri Jan 18, 2013 9:31 pm
Yes the DPO!
Kept us busy during my time at Renault! :mad:
Post Fri Jan 18, 2013 9:40 pm
Andyboy wrote:Depends which one. The ZF was not bad, the DPO a disaster. That piece of shit was fitted to lots of French turds. Changed the pollen filter on the red turd today, admiring the lack of rusty arches ;-)
To be fair to the frogs plastic front wings ftw :o:
Post Fri Jan 18, 2013 10:19 pm
One thing the French know how to do is build a body that doesnt rust!
Post Fri Jan 18, 2013 10:29 pm
Did you get the washer hose modded clio sunroof update Barry? :D
Post Fri Jan 18, 2013 10:31 pm
Clio sun roofs! :roll:
Forgot about those.
Andyboy
Alpina Colada
Post Sat Jan 19, 2013 4:40 am
. Unlike the rest of the galvanised shell, with alloy bonnet and tailgate. They 're as close to immune to rust as you'll get. Pity the electrics aren't as good. Gearboxes on petrols can go as well - not breakage, but a circlip pops out of the output flange causing loss of drive. Another one way trip across the scales. I think you can fix it with the box fitted.
As for that fucking keycard........ :cry:
Post Sat Jan 19, 2013 4:09 pm
As for that ******* keycard........ :cry:
The one my Mrs had was the Dynamique - it was mega comfortable with half leather sports seats and electric everything - shame it spent more time being fixed than it did on the road - apart from the issues with the gearbox we had heater matrix problems, recurring clutch pedal issues despite being repeatedly "fixed" by a main dealer, and the poxy tyre pressure warning sensors in the wheels failed over and over again- there was more stuff but I think I've managed to block it out. It was a VERY expensive 18 months of ownership and I've forbidden her from even looking at another french turd.
Anyway back to rusty engine-clad-with-plastic E46 scrap :D
Post Sat Jan 19, 2013 4:26 pm
I reset the fuel computer the other night after putting some squirt in as it had been taking an average of 30mpg over the last 800 or so miles, of which there had been a few motorway journeys.
Now i'm just running to work and back and around the ring road it's showing 19.7mpg. Which is pretty gash. I wouldn't mind if I was kicking it's head in everywhere, but that's from nannying it about. Bag o shite I tells ye
Post Sat Jan 19, 2013 4:41 pm
E30BeemerLad wrote:I reset the fuel computer the other night after putting some squirt in as it had been taking an average of 30mpg over the last 800 or so miles, of which there had been a few motorway journeys.
Changing the 'stat on mine helped with the MPG a little bit as it seemed to drink a bit more fuel when it was running cool
I dont go off the fuel computer though - fill it up and run it down to empty and calculate the mpg from that. The Fuelly website in my sig is a good way to keep track if you're geeky about that sort of thing :o:
Post Sat Jan 19, 2013 5:54 pm
How many miles to work Lee? Im 7 miles each way and if I dont get onto a decent journey between filling up its usually 16mpg in the E34, but thats at 68p per litre :)
Most auto 6 pot E46's I see are averaging low 20's
Post Sat Jan 19, 2013 6:01 pm
Yeah it's only about 7 miles each way to work, so maybe that's as good as it gets.
Post Sat Jan 19, 2013 6:22 pm
I would say so mate
pnd
Post Sat Jan 19, 2013 6:37 pm
i do ten miles to work and back in a 330i and get 25mpg so i would say yours should be at least early 20's.
Post Sat Jan 19, 2013 6:39 pm
I'll see what happens after the 'stat is changed and it starts running at proper temperature
Andyboy
Alpina Colada
Post Sat Jan 19, 2013 9:14 pm
Thrusting! Ours is the Expression with motor trade anthracite cloth and none of the electronic bullshit. Manual air con and a basic obc.
These cars only make sense if they're cheap enough to walk away from.
Post Tue Feb 05, 2013 6:47 pm
Has the water pump and thermostat etc changed today. What a noticeable difference to the level of heat coming out the vents, I actually had to turn the climate down for a change.
One of the lolipop bushes was utterly wankered and the other one wasn't far behind. The steering wheel no longer has a mind of it's own.
Had the geezer take a good look over the car whilst it was on the lift and no dramas on the radar, so all good then.
Hopefully the MPG may increase a little now as 19.4 is all I'm seeing going to work & back (and that includes generally driving it under 3000 rpm) I was getting better out of the chromie kicking it's head in everywhere.
