m20 idle high problem
RichS
Sun Jan 21, 2007 6:55 pm
I've been bashing my head against the wall on this one quite some time now. I've got an M20 that is idling high - 1000-1100RPM. Things I've tried so far:
Clean AFM, ICV & Throttle body.
Checked for vacuum leaks everywhere and replaced old pipes
Replaced blue sensor
Changed the connectors that go the fuel rail under the intake.
Tried replacment AFM
Tried replacment ICV
Checked TPS, cleaned it out as it was gunked up
It's got new fuel pump and filters, plugs, ht leads.
If I let it idle for a while and rev it up a bit, as the revs drop they go down to about 900rpm then back up to 1000. The engine runs smooth otherwise.
What else can I check?
parksie
Sun Jan 21, 2007 8:07 pm
Have you tried backing off the idle control screw :?
suzie650
Sun Jan 21, 2007 8:29 pm
parksie wrote:idle control screw :?
??? ICV, so the screw sets the minimal opening of the TB... not really to play with, I think
Sun Jan 21, 2007 8:40 pm
When the TPS gets gunked up and stops working , the engine will start to idle erratically and possibly cut out, a meat head appears with a screw driver and a hammer and magically 'fixes' the problem by winding up the throttle stop screw.
Cleaning out the throttle switch and fixing the initial problem will not cure things until the throttle stop is correctly adjusted. On opening the throttle with the engine turned off you should hear an audible click(if the switch is clean and working), adjust the throttle stop until you hear the click just off idle. This advice is good assuming no one has loosened and moved the throttle switch ! :(
RichS
Sun Jan 21, 2007 8:47 pm
Click is fine on the TPS used a multimeter to check it as well - and also the full throttle position.
