E36 Rocker Gasket
Zerotonine
Sat Oct 04, 2008 8:58 pm
I have just changed the rocker gasket on E36 316i, and now, every time I turn the engine off it weeps quite badly. Is there supposed to be a sealant on the gasket too? If so what sealant should I use?
town325i
Sun Oct 05, 2008 1:28 am
no its a rubber gasket and in does not need a sealer aswell it my have been tightend down to much and damaged the rubber
Jeepster
Mon Oct 06, 2008 9:00 am
I would use a sealant, only on the curved parts of the cover though.
The studs have a collar on them, in fairness they really shouldn't tighten down much, they hit the collar when tightening by hand and you just nip them up after that. I would be getting a new gasket and hoping for the best.
Edit: I've just checked the torque rating, they should be 10nm. Not a lot at all.
Zerotonine
Mon Oct 06, 2008 9:46 pm
I have just put some sealant on, hoping it will now hold!
town325i
Mon Oct 06, 2008 10:40 pm
you will hope you havnt put to much on that stuff can block up oil ways i striped two heads of 2 e30's last week and the oil ways where full of the stuff
