evolve chip not again goto ant
hongkongfuey
Mad-tango-geezer
Post Sat Jan 12, 2008 2:52 pm
, this is an ok mod for a 325 , speedtouch does the same for cheaper, but if you want to wake up your e30 get one from ant
with cars like mine,
march109
Post Sat Jan 12, 2008 2:57 pm
I'm a fan of the evolve chip too, but can't forget Ant does them also and I had good results from that too.
alex-e30
Post Sat Jan 12, 2008 3:08 pm
what are these chips like to fit, i fitted one myself before but the car just ran lumpy with loads of flats spots, i was told it was because i bought it off ebay :o: can i fit these evolve chips myself?
this is my beemer, there are many like it but this ones mine
(OO=[][]=OO)
blitz877
AKA ajm-e30
yes you can mate
alex-e30
Post Sat Jan 12, 2008 3:12 pm
did my last one mess up because i got it off ebay?
(OO=[][]=OO)
Post Sat Jan 12, 2008 3:16 pm
Did you let it idle for 10 mins on fitting it to learn the base idle settings, prior to switching off then going for a drive?
blitz877
AKA ajm-e30
Post Sat Jan 12, 2008 3:17 pm
probably not :mad: winkeye
alex-e30
Post Sat Jan 12, 2008 3:26 pm
Speedtouch wrote:Did you let it idle for 10 mins on fitting it to learn the base idle settings, prior to switching off then going for a drive?
no mate, i just pluged in a played winkeye
(OO=[][]=OO)
Post Sat Jan 12, 2008 3:38 pm
That probably explains it then. You need to 'bed in' the chip properly for it to work at its best, rather like a set of new brake pads.
agreen
Post Sat Jan 12, 2008 5:53 pm
the evolve ones come with colour instructions i think if not ask sal i am sure he has some he will help you out :P
scaraveos
Post Wed Aug 26, 2009 1:16 am
guys, what happens when you disconnect the dme from the battery? i have a electrical switch on my car and turn it off every time i park the car. does it affect anything? i don't have a chip(yet).
hongkongfuey
Mad-tango-geezer
Post Wed Aug 26, 2009 11:20 am
i wouldn't buy one from evolve again, if you want a chip go to ant
JWaller360
Post Wed Aug 26, 2009 8:08 pm
does Ant do chips for the iS?
Steve-E30
East Sussex Hooligan
Post Wed Aug 26, 2009 9:39 pm
I didnt think ant did i.s. chips but maybe wrong
Know quite a few people who have evolve chips and if theres a problem i bet they would sort it .
Did you bed the chip in as mentined and what was so bad about it ?
You havent exactly explained what the problem is either :roll:
Giggety Giggety Goo!!!
hongkongfuey
Mad-tango-geezer
Post Wed Aug 26, 2009 10:48 pm
bad fueling and timing over advanced, tick over on cold start was 1100????????
had a 'super chips' chip in an ecu i picked up put that in ran like a dream, but know will only goto ant
Cotty
Hartge Crew
Post Wed Aug 26, 2009 11:48 pm
I have an Ant chip and very happy with it
Steve-E30
Post Thu Aug 27, 2009 12:47 am
Ants chips are good but was unaware he did them for the i.s.
Hkf did you buy the chip direct or off someone else ?
Only reason i ask is the last few people i know that have bought them im sure they asked for ecu number ?
If you bought direct and your not happy ask for a refund ... simples
The_Diddler
Love it up the more door !
Post Thu Aug 27, 2009 12:58 am
Cotty wrote:I have an Ant chip and very happy with it
What difference does it make to the b25 :D
hongkongfuey
Mad-tango-geezer
Post Thu Aug 27, 2009 3:04 am
this thread started jan 2008, it was direct, gone now, got one coming from ant dyno pics to follow
Steve-E30
Post Thu Aug 27, 2009 3:09 pm
Just noticed that now you mention it after the random bump .
UweM3
Post Sat Aug 29, 2009 11:22 pm
scaraveos wrote:guys, what happens when you disconnect the dme from the battery? i have a electrical switch on my car and turn it off every time i park the car. does it affect anything? i don't have a chip(yet).
M3 or other E30?
M3 doesn't matter
jmc330i
Post Sat Aug 29, 2009 11:27 pm
M3 or other E30?
M3 doesn't matter
Does it matter on any other E30?
James
'91 325i Sport
'93 318i touring 16v
Post Sun Aug 30, 2009 12:57 pm
It doesn't "matter" as such - no harm will become of it, but you should in theory always allow the engine to idle for at least 10 minutes before switching off then driving as normal, otherwise there is the possibility of the idle running rough due to the base idle map being disturbed.
