Speedtouch (Trader)
Great chip, excellent service, cannot recommend enough.
This time I purchased a wild 325 chip, the difference was amazing, so much better to drive now.
Previously I have had a 325 mild and 335 chip from speedtouch, every time the chip and the service have been first class.
- E30SPORTMAD
Hi top guy and rapid quick service and top quality chips at very good prices, A******
hi mate i have a 1990 G reg 320i. i remember somebody mentioning you might not do chips for my particular car being a facelift but i thought id ask anyway.
im looking for something that will improve mid range torque or at least allow me to use what i have abit more effectively. right now it feels as if i need to rip the bollocks off of her to achieve anything. i do a mixture of town and motorway but I'm forever cruising so the revs sit between 1-3.
in your opinion which would be the best chip to go for to achieve this, could i have a quote incl. delivery to west london. oh and finally a simple procedure process or something along that line just so i don't screw it up haha.
cheers. Asad.
cheers. Asad.
PM sent!
Thanks,
Thanks,
Fitted a Mild chip to my 320i and what a difference! The car feels so much better with the throttle response
Thanks very much, a happy customer
I second ALP1NA there-Speedtouch is super polite, very helpful, dispatches the same day (even if you pay as late as 3pm) and his chips are fantastic!
I have 3 325i's, and have chipped two of them with his chips. The improvement in torque in the lower rev range is very noticeable, and it really evens out performance across the M20's rev range. The only car left to do is my older motronic 1 car, which is a trickier beast to source a chip for. Having said that, Speedtouch is still trying to source one for me.
I can't recommend him or his chips enough. They really are excellent!
'87 325i cabriolet, manual, Zinnobar Red
'91 325i se coupe, manual, Laguna Green
- mrcharliechan
Installed mild chip into my 320i cab and very happy with the results. Much more snap to the acceleration and very smooth.
Also top seller as post office managed to lose chip and Speedtouch promptly sent out a replacement.
Great service, great product, highly recommended.
- gooseygander110
- Contact:
Thanks Maurice........ really helped me out ...... clearly knows his stuff ....well recommended...
Let me take the opportunity and once again publicly commend Speedtouch that is, without a word, he sent a replacement chip when I complained to him that the shipment is delayed. Truly generous is that once again a big thank you Speedtouch.
No problem, thanks again, Zoran.
I recently installed a wild chip by speedtouch.
-idle is great (i had bad idle because of porting and bigger injectors)
-spark plug and exhaust have a nice chocolate color!!!
-power gain is excellent through all RPM range
-engine response is faster then the gas pedal
-chip also work well with old vacuum LPG system
i order 7200 rpm limit but my taho say less then 7000, i'm sure that problem is with the taho, not with the chip.
soon i will order Wild chip for m20b20 for other touring in my family.
Tnx Zoran for ordering chip for me!
tnx speetouch for nice job!!!
sorry for my English!
Even though I walk through the valley of the shadow of death, I fear no evil, for You are with me; Your rod and Your staff, they comfort me.
(23:4)
(23:4)
Good to hear you've had a good result with this chip, Suki. Nice little clip!
Very promt payer, easy to communicate with. the item I sold maurice turned out not to be what him or I for that matter expected. He was very understanding however, and we managed to get things sorted out. Credit to the zone and I intend to do ecu related business with him again soon!
Raise hell praise Dale.
Great delivery speed, good guy to deal with, yet to install - will update soon!
i order another chip, this time wild for m2020.
What to say... nice job!
regards
Suki
regards
Suki
(23:4)
(23:4)
- aivaras325
Installed Wild for M20B20 and I am happy that I did. Power seams to come at lower revs and reving itself improved.
Spoke to maurice the other day about a chip for my b27 conversion
2 days later a chip lands on my door,
after my b27 conversion it wasnt really what i expected, no real extra power, only benefit (weirdly) was an increase in mpg.
after the fitting of the chip, all i can say is WOW, instant throttle response, a truck load of low down torque and still a decent kick at 4k rpm, 2 days later and the extra power and torque is still suprising me and putting a smile on my face,
all i can say is fantastic guy to deal with, nothing is too much trouble,
once again, thank-you very very much
My pleasure!
Thanks again for your custom.
Forgot to update, not bad at all on the wild chip for my m20. Not bad at all.
Built a 2,7 lump about 2 years ago and the chip I had from another well known chip supplier acted like an on/off switch. You were either going at 90 or changing down to 2nd to keep it below 30.
Also the map would switch off the petrol on the overrun so if you took your foot off the gas in any gear but 5th it was like driving into treacle.
This morning I fitted the chip from Speedtouch and all these problems vanished, the car was a joy to drive.
This chip has done everything I hoped it would and at a third of the cost of the first chip.
Of course the first chip is ideal for track days so it is horses for courses.
Big praise to Maurice for giving me a car that after all this time I can finally use everyday. Thank you.
Speedtouch rocks. Thoroughly recommend you have a mild chip from Maurice if you do nothing else to your E 30. Made such a difference. Great product and great to deal with. Suits my car well. Thanks
- lenruygrok
I ordered / payed and shipment was done immedeatly ...
Postal service a bit slow, but maurice was kind enough to often answer my questions about al kind of motortuning considering the /E30.
installed the chip, and wow ! the engine came alive !
tnx ! great performance ! great seller !
- Contact:
installed my WILD CHIP along with shrickk cams, BTB 6 branch and a few other tweeks. and all i got to say is damn, the car feels like a different car, huge increase in power and much better throttle response.
thankyou speedtouch.
top seller
top seller
