number plate surround spraying
beefy
Post Mon Mar 03, 2008 8:56 pm
hi all im thinking about painting the rear plastic number plate surround the same colour as my car. How do i do this and what paint etc do i need. I will be using a spray gun to do the job.
Any help appreciated.
sam325is
Post Fri Mar 07, 2008 1:43 am
clean thoroughly wit fairly liquid. use adhesion promoter and spray.
zeeks
Post Mon Mar 10, 2008 10:01 pm
The adhesion process is crucial i have had probs in the past where after time paint begins to peel just with washing due to the plastic adhesion promoter not doing the bizz.
fuzzy
He who sleeps with "Gingers"
Post Mon Mar 10, 2008 10:03 pm
sam325is wrote:clean thoroughly wit fairly liquid. use adhesion promoter and spray.
wouldnt it be better to clean with a spirit based cleaner that wont leave a soapy film over it? rub with wire wool to give a rough key for the paint to stick better to.
sam325is
Post Tue Mar 11, 2008 7:17 pm
maybe it would. but i would still suggest adhsion promoter unless you want to faff around with it every year or so
