Treating rust
david106
I've taken the side skirts of my touring and theres a little bit of surface rust near the jacking points so the question is what should i treat it with and should i just paint over it.
e30den
don,t paint over it [bad idea] get some bilt-hamber rust treatment and prevention stuff to stop it spreading.
march109
If you really want to treat it you can't go wrong with choccies and flowers.
Although If ou must pop into halfrauds and look for the paint on rust inhibitor stuff, but if the problem goes deeper, cut out and weld in fresh is the best way to go.
david106
its looks like its only surface rust at the moment so i will sand it out and treat it
bodger
dont sand too much off as the treatment needs a little rust left to react.david106 wrote:its looks like its only surface rust at the moment so i will sand it out and treat it
ian332isport
david106 wrote:so the question is what should i treat it with
goosiegander
- Zonegoose
ok sand back to bare metal with aluminum oxide paper, use some k-rust followed by zinc primer followed by primer and then topcoat as required
david106
where can i buy k-rust? is it a spray or brush on
goosiegander
- Zonegoose
its brush on and halfords or wilco should stock it
david106
cheers hopefully i will have my car on the road sometime this year
so we can sort a meet out
goosiegander
- Zonegoose
cool stuff theres quite a few e30 over the city, i'm fixing one tomorrow
david106
I feel like setting mine alight at the moment lots of little jobs to do no garage and crap weather
Aziz
HI I got some POR 15 Rust Prevention Paint from this company below
www.frost.co.uk excellent product have not seen any rust for 2yrs since painting
