calling jon!!!
squeal
looking to buy more zaino,i only have z2 pro which i believe is for clearcoats-however my work van is the vehichle in question-it has regular paint so i was going to order z3,however seen z5 pro too-is this for all paint finishes..my second question is the zfx accelarator-my usual process on my car is after prep to use a thin layer of z1 followed by a thin layer of z2 pro using z6 as necessary-am i doing wrong??my thots on the van detail would be to go through the necessary prep stages and after all correction to apply a thin layer of z1 followed by z3-would this be correct or do i need the zfx system physics?i was intending to layer the z3 after the next wash in a few days also..ny help much appreciated jon-thanking u
c76jon
ok
z1 is my preferred method
zfx is instead of z1
z5 pro is unreal and get it asap its good for al types of paint
it has some very fine filling qualities too
if u can stretch to it go for z8 aswell..........amazing
your method is spot on
2 new products launched
z-aio an all in product • Apply by hand or machine
• Safe for all paint types
• Restores dull paint & minor oxidation
• Safely smoothes minor flaws & cleans embedded debris
• Leaves a glossy & strong protective layer
• Excellent base coat setup for optional Z-2 PRO or Z-5 PRO application
• Does not contain any oils or fillers
this is replacing z1 so acts as first layer before sealants
also
z-cs
Zaino Z-CS Clear Seal is finally here after years in development. From conception to realization, the principal and design emphasis of Zaino Z-CS Clear Seal was quite fundamental - an advanced total synthetic polymer protectant that is simply wiped on, and that's it! Yes, achieve Zaino award winning gloss and protective durability in ONE simple wipe on step. Wipe on, and walk away, you're done. No buffing. No final wipe down. Simplicity at it's best. Just apply & let dry.
i know several people that have beta tested this and its jaw dropping
this can be layered with either z2 pro or z5 pro but the z-cs is always final coat followed by z8 or z6
it can also be used on top of any other manufacturers product
id prep van and layer z1 on
then coat of z5 pro or z3 and then mist with z6 or z8 then layer with more z5 pro or z3 and final z8 or z6
then leave for at least 24 hours and continue to layer
max two layers of sealant on first day
hth
jon
also
z-cs
hth
jon
squeal
excellent jon-so z5 pro is the better choice then,should i be getting the zcs to layer too?is it uk avalable to??
c76jon
z5 pro a better choice imho
zcs is not in uk yet but its on its way
yes zcs can be layered too
jon
jon
