refurbishing bbs wheel's diy
david106
Post Thu Oct 26, 2006 1:08 pm
Has anyone had a go at doing it yourself , I've got a set which are ok they just need a repaint .
Grantley
Post Sun Oct 29, 2006 4:36 pm
I've just finished rubbing down a set of 5 BBS's by hand and my mate is etch priming and then painting them for me and while I'm looking forward to getting them finished and the feeling of satisfaction knowing that I did some of the work myself I'm never doing it again, ever :mad:
tobias
Post Sun Oct 29, 2006 9:05 pm
as above but only half way through and already cursing the day i started :cry:
Sooty
Post Sun Oct 29, 2006 9:31 pm
I started on the first one of a set a few days ago.
Anyone know how long it takes to grow fingerprints back......?
:surrender: :cens:
tobias
Post Sun Oct 29, 2006 9:41 pm
is anyone working on 17 inch splits???
jonbuoy
Post Sun Oct 29, 2006 10:01 pm
I did all 5 of mine.....
Cleaned them up with celilose thinner's with an old tooth brush, took a very painstackingly long time :cry: ...
Sprayed them with thick primer paint, light sand back with 600 wet'n'dry.
Haven't got a photo of when i covered the centre and painted the rim for some un-none reason :? but here's the other's.......4 of the wheel's are sprayed with paint from the local AutoCare :D
And the finished article after laquer :mrgreen:
tobias
Post Sun Oct 29, 2006 10:03 pm
nice 8)
reddevil
Post Sun Oct 29, 2006 10:09 pm
They look amazing Mate, do you proud.
Red D
1991 (H) 318iS Diamond Black, M-tech II spoiler.
K&N Panel filter-Viper2 chip-Zone BBTB
XBOX LIVE - reddevil1976
geo1400
Post Fri Nov 03, 2006 9:04 am
They look awesome mate! wish I had the patience...
Grantley
Post Mon Nov 06, 2006 6:52 pm
They look really nice mate, well worth loosing your fingerprints for a few weeks to get a finish like that :mad:
muleskinner
Post Tue Nov 07, 2006 10:06 pm
easiest way.... get em shot blasted or acid dipped to remove old paint , then powder coat em....trust me , with all the time and money you would spend on paint etc , the above will cost you about Ԛ£25.00 per wheel.
cheers
mule
SHAZ325iSPORT
Post Tue Nov 07, 2006 10:15 pm
i done these my self aswell,check out before and after!
these are 16" BBS 8J all round,for sale aswell if anyone intrested!
FROM THIS-
TO THIS-
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Nov 08, 2006 12:49 am
Shaz what did u use to achive that polished lip?? they look fat as
SHAZ325iSPORT
Post Wed Nov 08, 2006 11:01 am
well the alloys were kurbed,so i grinder out,put a sanding disc on and sanded em down ,then got wet & dry and then used autosol.
Morat
Post Thu Nov 09, 2006 11:23 am
muleskinner wrote:easiest way.... get em shot blasted or acid dipped to remove old paint , then powder coat em....trust me , with all the time and money you would spend on paint etc , the above will cost you about Ԛ£25.00 per wheel.
cheers
mule
Have you got any pics of powdercoated BBS? I know someone who does powder coating professionally but I'm not sure it would look right on alloys?
edit: what about white powder coating to go with my white touring? :)
Rik178m
Post Thu Jan 24, 2008 7:40 pm
Which paint do you use for silver?
Can you do this with spray cans and how long will it last?
What laquer do you use?
arcdef
Post Thu Jan 24, 2008 7:52 pm
Rik178m
Post Thu Jan 24, 2008 8:14 pm
Cheers Sounds like a plan! winkeye
agreen
Post Thu Jan 24, 2008 10:02 pm
what sander was this are they on ebay ?
Chris
Post Sun Feb 17, 2008 12:14 am
Angle grinder with a sanding flap disc.
Removes Aluminium very quickly though so be careful.
