Loose dechromed trim on drivers side
eldarvanyar
Post Thu Aug 10, 2006 8:58 pm
The dechromed trim that runs across the roof and down the drivers piller has come loose. I've got some sellotape holding it down at the moment. Any ideas as to how to fix it, is there a special sealent / adhesive to use or do I need new trim?
smithy318i
Post Thu Aug 10, 2006 9:06 pm
glue
eko
Old timer
Post Thu Aug 10, 2006 9:09 pm
Blob of araldite(or similar) and it wont be going anywhere :)
Chris-W
Post Thu Aug 10, 2006 9:20 pm
Or pinch the two attaching strips together slightly.
SCOTT325SE
Post Thu Aug 10, 2006 9:24 pm
you can PROBABLY remove it and pinch the stuff so it grabs tighter, but ive got a complete dechrome kit that im selling if you wanted a new set. Try the pinch method 1st though for cheapness of solution
eldarvanyar
Post Thu Aug 10, 2006 9:26 pm
Thanks guys wanted to check with the experts first, :D
