alloy polishing
red_beemer
Sat Feb 18, 2006 11:06 pm
hi
how would you actaully get a polished lip on your alloy ?? its a standard bbs wheel
i'm midway of refurbing mine, currently i'm at the sanding stage so would like any tips on how to get it polished
thanks! :cool:
kam-325i
Sat Feb 18, 2006 11:08 pm
Do you want to polish it yourself ?
red_beemer
yup! any tips? 8)
kam-325i
Sat Feb 18, 2006 11:16 pm
Look into buying a polishing kit, Dremel do a home kit for about Ԛ£20-30.
oguz327
Captain Armco
Captain Armco
Sat Feb 18, 2006 11:19 pm
do you know if the dremel kit will fit onto a normal cordless, or do you need a dremel for the kit?
kam-325i
Sat Feb 18, 2006 11:52 pm
oguz3001 wrote:do you know if the dremel kit will fit onto a normal cordless, or do you need a dremel for the kit?
If the chuck on the drill will accept a 3mm drill bit, then yes, but the drill will need to be cappable of above 800-1000Rpm due to the small size of the kit, Bigger mops/disks need a slower speed.
gcorky
Boost Junkie
Tue Feb 28, 2006 1:38 am
get em in a lathe....will be hard work stripping back and polishing with drills and the like :(
525 sport
Lowm3
Mon Mar 13, 2006 9:58 am
There is a good kit on frosts website. It about 45 pound.
Great for people who want to give it a go them selves, and for small areas like ips of wheels.
IԚ´m not sure if its compatible with a regular drill. should be fine as long as the mops large enough. The compounds are supplied with the kit.
hope this helps :cool:
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Mar 15, 2006 9:41 am
this is a mod i wanna do to my 15's, i think it looks great
Lowm3
Sat Apr 01, 2006 6:25 pm
The frost kit is definately the best one for a DIY job, closest you will ge to a professional job.. or you can give me a shout and check some of the finishes we do in the gallery here: www.pureklas.co.uk
What wheels are thy that people are refurbing, as its best to polish to a line, if your wheels have one. :wink:
