Removing spray glue.
Posted: Mon Jun 24, 2019 11:19 am
by Foe
As the original dash had a crack or two, my mate covered it in a leather cover which had been sprayed glued on.
Is there anything I can use to remove this glue without causing too much damage?
I've only removed a bit under the dash, so happy to experiment with any glue removal recommendations.
Ta
Re: Removing spray glue.
Posted: Tue Jun 25, 2019 11:27 am
by Steve
Have you got any photos of the dash?
Posted: Tue Jun 25, 2019 1:31 pm
by flybynite
For a lot of glue residue, normally things like tape residue I use WD40, it would be the first thing I would try.
Posted: Tue Jun 25, 2019 5:06 pm
by Ozu
We’ve got a can of ‘Sticky Label remover’ under the kitchen sink. It’s really good. Made by Tableau. We bought it in Hursts on the Isle of Wight
Posted: Tue Jun 25, 2019 8:17 pm
by Foe
Steve wrote: ↑Tue Jun 25, 2019 11:27 am
Managed to get this one, as I've started somewhere inconspicuous first, next to the the glove box, so I can test some products first.
The white stuff is the glue.
Posted: Tue Jun 25, 2019 8:18 pm
by Foe
flybynite wrote: ↑Tue Jun 25, 2019 1:31 pm
Worth a shot, thanks.
Ozu wrote: ↑Tue Jun 25, 2019 5:06 pm
Might have to check the internet for that one if nothing else works.
Posted: Fri Oct 25, 2019 3:15 pm
by rix313
Autosmart Jelsol is pretty good stuff but it is on the aggressive side so I would recommend a small tester first.
Posted: Sun Nov 17, 2019 9:58 pm
by Foe
rix313 wrote: ↑Fri Oct 25, 2019 3:15 pm
Thanks. The dash was so bad and beyond saving, I picked up a second hand one.
