spraying body kit
clemQ
Sat Dec 17, 2005 10:47 pm
ive just got hold of an m-tec kit in blue, but my bm's silver. ive sanded it right back to the base white (hard work) and filled in any chips and sanded everything smooth. what i want to know is whether i have to sand between spraying layers or when??? apparently after the final coat, i have to wet n dry evrything before applying the laquer but im a bit confused with all this sanding malarkey, so if any1 can help me out that would be sweet.
oguz327
Captain Armco
Captain Armco
Fri Dec 23, 2005 2:03 am
easy clem
i think once you have done the first rub down and then put ur primer on, then its a case of rubbing down again with a fine grade paper.
one u have done this then put ur silver base coat on then once dryed ur laquer. use flexible paint.
worked in a body shop for a short time a long while ago, so correct me if i am wrong anyone!
E30Mark
Fri Dec 23, 2005 12:21 pm
Never rub down the colour coat before lacquering!
If you've never sprayed before, then i suggest you find something easier to learn on...
You will need a decent paint with plasticisers mixed in to stop it chipping off.
I would practice on one of the smallest pieces first, I assume your using a compressor / gun not aerosols....
PM for details
scottybeemer
Mon Dec 26, 2005 10:56 am
E30Mark wrote:Never rub down the colour coat before lacquering!
yep he's right,once base coat is on DONT touch it ,just get the lacquer on!
"you aint gonna take me alive, copper"
oguz327
Captain Armco
Captain Armco
Thu Dec 29, 2005 10:53 pm
sorry, ur right guys what was i thinking, too many stellas lol :oops:
