Help needed with restoring black trim
fearlessphil
hey guys i tried to resurect some of my faded black trim peices with bumper back to black with no joy! what would you recomend? i hate the trim it should be black but is a horrible light gray!
Try some t-cut, you might be suprised. It certainly helps get rid of the small scratches and marks. I used autoglym polish [similar to t-cut, but less abrasive] on mine the other day and was shocked because it almost looked brand new after
I don't know if it works for all black trim, but apparently peanut butter will bring the black number plate trim up nicely - smooth peanut butter, not the crunchy stuff.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- Kos
- Contact:
used engine oil
next you'll advise that a brillo pad and brick acid is good for alloy wheels
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
A heat gun session followed by chemical new look trim dressing will give pleasing results.
- tommygoldy
Mer polish works well IME although go easy on matte surfaces as it's slightly abrasive and may make them shiny if you overdo it. Safer and easier than T-Cut though.
I tend to use boiled lindseed oil (generally used on woods) or when i can get hold of it from work i use a silicone spray, makes them look brand new and makes the water just bead off, much like polish, Boiled lindseed oil does the same.
hair wax (dax)
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
