I was going to wash with dodo juice sour power then clay bar the car. Fine / medium cut the paintwork depending on how much it needs, using mezerna compound or maybe the zaino all in one (polishing pad).Then apply Zaino Z2 pro car sealant with flash cure addiditve - Am i able to use the polisher to apply that with the finishing pad? And finally use Zaino Z8 grand finale stay seal.
Does that all sound ok? Whats the best way to use the polisher (high speeds for fine cutting, slow for heavy? Use the machine in a circular motion?) How safe am I to use the polisher on the painted plastic on the front and rear bumper? I assume I will have to spray water onto the paint while I'm using the polisher to prevent burning?
