How to remove glue?
ALP1NA
Sun Jul 08, 2012 4:02 pm
I bought a new sponge and would change it but can not seem to take off the glue. I tried with a thinner oil and gasoline but unfortunately nothing. Is it someone has experience and can you recommend a tool that will easily remove the adhesive residue and without damaging paint. Thank you.
chh137
Sun Jul 08, 2012 4:04 pm
Brake cleaner , elbow grease and patience.
gare30
Sun Jul 08, 2012 8:02 pm
tar and glue remover
pukar
Sun Jul 08, 2012 9:32 pm
the old glue is sticky....the new glue is sticky
stick the new panels over the old glue.....they will outlast the car for sure and save yourself a gluey sticky mess and 1 day's work
snakebrain
Thu Jul 12, 2012 9:20 pm
I used thinners/white spirit on a kitchen sponge and a plastic spatula. It will come off. Cover the engine bay with a sheet or something or you'll be spending the next 6 weeks pulling bits of glue off it.
Or just stick it on over the old glue as pukar suggested..
Cloggy Saint
Thu Jul 12, 2012 10:15 pm
Another vote for sticking on the old glue. I did that a few years ago and it's showing no signs of coming off.
Dan320is
Wed Jul 18, 2012 6:21 pm
I have just done this.
Take the bonnet off, it's only six bolts, washer pipe and strut disconnected.
I found an old duvet to lay the bonnet on and used petrol with a cork sanding block - http://compare.ebay.co.uk/like/12093509 ... adtype=pla
The paint wont be damaged and the new pads will adhere properly. I tried to stick the new over old glue and it didn't work.
aimlessrock
Sun Jul 29, 2012 4:03 pm
much the same as the above, mine was in an appalling state. I took the bonnet off and used thinner and a sponge...took most of an afternoon to get it all off!
E30 320i Convertible (1989)
190 Mercedes (1988)
Topblag
Sun Jul 29, 2012 4:10 pm
Did mine recently, bonnet was going for a full paint. I could only get Winns brake cleaner, worked well but I went through most of an aerosol and found only a metal scraper would do.
Make sure it's in a well ventilated area as it's not nice to breathe in brake cleaner.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
