E30 Elephant Trunk
Racer75
Post Fri May 18, 2012 7:00 pm
Hi guys,
My e30 has a water leak on the passenger side. I heard about 'elephant trunk' and went to investigate. Turns out it was totally corroded.
Will it be alright not to replace it or is it vital?
Post Fri May 18, 2012 7:14 pm
The elephant trunk is rubber, or do you mean the metal lip it fixes around has corroded away?
It is preferable to have one as otherwise the water that drains from the heater box area drains down behind the sound deadening material on the bulkhead and transmission tunnel.
Racer75
Post Fri May 18, 2012 7:45 pm
Thanks for the response.
It was the rubber bit that was totaled.
e30-EVN
its a pretty vital piece, albeit a small part but unless you want your bulkhead to rot or wet feet i'd get a new one soon.!
Racer75
Post Fri May 18, 2012 7:48 pm
Do you know where I can get one?
e30-EVN
Post Fri May 18, 2012 7:49 pm
i would think its a dealer only item mate to be honest, either that or a wanted thread on here should find you one for next to nothing :wink:
Post Sat May 19, 2012 5:49 pm
Dealer only and about £20 ! :eek: Used is a waste of time, unless it has been recently replaced, it will be rock hard and virtually impossible to refit securely.
