polishing
jimmypee
If i were going to machine polish a car using maguires compound do you need to use water with it or does it self lubricate
- E30 Zone Meets/Events Team
LOADS OF WATER!!!!
twoscoops
depends on what compound you are talking about from Meguiars, 105, 205, D300???
e30den
No water is needed at alljimmypee wrote:If i were going to machine polish a car using maguires compound do you need to use water with it or does it self lubricate
Mike-
Never used any water with a machine polish, bit of spray on the pad before you start and job done.
twoscoops
yip i agree. A spritz of water to prime the pad and then you the correct polishes.
Kos
with the older type compounds water was needed but with the modern stuff its not required. i is handy to have some close by to cool down the panel if it gets too warm
m8782538
I use megs 105 and 205 and they are fine to use as they are, just prime your pad as normal and you will be ok.
