best stuff to remove light scratches
matt86
Post Tue Apr 03, 2012 7:46 pm
Hi whats the best stuff to remove light scratches?
g3 compound, t-cut or is there anything else? its for a metallic car.
cheers :D
kolee
Post Tue Apr 03, 2012 7:51 pm
Alot of the stuff on the shelves i find too abrasive for old paint (at least for mine) The auto glym resin polish i used seems quite nice.
I think most people would go for a touch up pot of paint on a cocktail stick, then blend it in with compound?? Edit: probably better for deeper scratches.
matt86
Post Tue Apr 03, 2012 8:13 pm
thanks kolee, I've got that too, so will give that a go. Hows your car coming along? if you need any bits give me a shout as may have them, or if you ever want a hand with it or anything. cheers mate
toby
Post Tue Apr 03, 2012 9:30 pm
The Autoglym Super Resin Polish is said to have some filling compound to fill scratches slightly at the same time as a mild cutting and waxing.
matt86
Post Tue Apr 03, 2012 9:47 pm
thanks toby, I'll give this a try this weekend. :)
Kos
Post Tue Apr 03, 2012 11:27 pm
the super resin polish is exactly what it say it is, a polish
it will polish out very very light hazing/ fine scratches but it mainly re vitalise paint. if you apply it with a rotary polisher you can have amazing results and it will mask and get rid of swirls
a good all rounds product but to get the most out of it, wax or use a sealant after
twoscoops
Post Mon Apr 09, 2012 4:18 pm
You wont find better than Gtechniq P1 for both use by hand or by DA or rotary. It will also refine done to leave a pretty much hologram free finish. Super Resin Polish is also a great alternative just make sure you are not using more than the size of a pea per panel and work it with medium pressure until it goes clear. Dont just wipe it on and leave it. You should then do the next panel and when that is finished come back and remove the previous one.
Hope that helps!
Post Mon Apr 09, 2012 4:26 pm
Get yourself donw to Halfrauds, there's a 2 for 1 offer on the Autoglm stuff.
matt86
Post Mon Apr 09, 2012 9:33 pm
Rav335uk wrote:Get yourself donw to Halfrauds, there's a 2 for 1 offer on the Autoglm stuff.
nice one rav appreciate the "heads up", will get stockpiled up. :)
m8782538
Post Fri May 04, 2012 12:57 pm
AG SRP contains some fillers so won't actually remove all traces. you need a propper polish, use megs, 3M, Mezerna etc, use a fine grade polish and it will remove the scratches in no time.
