Refurbing pre face rubber bumper trims
SilverShadow
Hartge Crew
Post Fri Oct 07, 2011 4:13 pm
Thinking whether there is a process of refurbing the rubbers on the bumpers on a pre face lift models?
The chrome bumper mouldings?
Z3I
Post Fri Oct 07, 2011 4:21 pm
If you've just got marks and scratches on them, Ive sucessfully used wet n'dry to bring about a better look.
Use a coarse grade, like 100-200 to take out any scuffs, then use a finer grade like 600+ over the entire bumper to bring about and even sheen to the whole bumper.
The finer the grade, the shinier it is finished.
SilverShadow
Hartge Crew
Post Fri Oct 07, 2011 5:46 pm
Thanks z3
I assume the same method can be applied to the Side trims?
The shadow line trims around the windows I am thinking of painting in satin black....?
Z3I
Post Fri Oct 07, 2011 5:53 pm
Not tried the side trims. If you've got a spare piece of trim, try it first, see how it matches?
Same for the bright trim, try rubbing it down with wet n'dry before you paint with satin black , to give the paint a key so it doesn't chip so easy.
Good luck!
