Pinstripe removal
Davies31
Mon May 16, 2011 9:14 pm
Anyone know the best way to remove pinstripes.
I have bought an E30 in Lachs Silver and it has a black pinstripe down both sides, but it has been on some time and is missing in patches, creating an untidy broken line appearance.
I have removed some of the pinstriping. The black vinyl comes of easily when picked with a razor blade. The problem lies in removing the adhesive line underneath.
I have tried boiling water.
I have tried WD40
I have tried White spirit.
Any ideas or tips borne of experience most gratefully appreciated.
Jim
threelander
Mon May 16, 2011 9:17 pm
hot water worked for me or a hair dryer on hot but it is something that can,t be rushed needs patience mate
m8782538
Tue May 17, 2011 8:34 am
Ispropyl Alcohol should do the trick, use sparingly with a clean cloth. Or can try Bug and tar remover but remember you need to wash and polish, wax aftewards.
Ranchero
Tue May 17, 2011 10:18 am
Lighter fluid and patience.
Davies31
Tue May 17, 2011 12:52 pm
Will the Isopropyl Alcohol or the lighter fluid damage the clearcoat or the paint finish in any way. I appreciate it will remove any wax finish already on the car.
Do they need any diluting before applying?
Will there be any further damage?
m8782538
Tue May 17, 2011 12:55 pm
shouldn't damage to lacquer at all, Isoproyl Alcohol is what you prep bodywork with for paint, It just cleans the surface. one the sticky stuff is off, i would give the whole car a good polish and a couple of coats of wax anyway.
badassyas
Tue May 17, 2011 12:56 pm
Google "caramel wheel" bought for about a fiver... Put it on your drill and the pinstripe will be off in no time without damage to the paintwork.
m8782538
Tue May 17, 2011 1:24 pm
caramel/ toffee wheels do work but if you apply too much pressure it has the opposite effect, it makes a bigger mess.
Davies31
Tue May 17, 2011 2:15 pm
Caramel Wheel?? :?
Ranchero
Tue May 17, 2011 4:27 pm
Lighter fluid wont harm the paintwork. Just apply neat to a rag and get rubbing.
mikehoddy
Sun May 22, 2011 10:46 pm
'sticky stuff' remover from halfords - bloody dood stuff when removing sticky adhesive residue
vendetta
Thu May 26, 2011 8:43 am
Heat gun used gently
